Change discovery rule on host level - best practice?
  • JohnDoe1113
    • Nov 2020
    I currently need to add dependencies for trigger prototypes for a group of hosts, where the dependency is unique to each host.
    I was thinking about adding the dependency on the trigger prototype on each host in the discovery rule, just like you would on a normal trigger (not discovered)
    Would this be bad practice, or is this the recommended way of adding unique dependencies to triggers pr. host when dealing with trigger prototypes from a discovery rule?
    Thanks in advance
