Monitor MySQL
  • Villain
    • Aug 2006
    • 84
    Monitor MySQL
    Not sure if this is the correct place or not (maybe cookbook?), but we're having problems with monitoring MySQL connections now.
    I uncommented the items in the zabbix_agentd.conf file so that mysql should work. However, on the server, I am told that all of the commands listed in the MySQL_t template are not supported.
    Did these change, as well?
    What do others use to monitor MySQL connections?
  • Villain
    • Aug 2006
    • 84
    Fixed!
    The templates use mysql[command] but the agent supports mysql.command instead.
    If possible, the template for mysql_t might need to be updated to reflect this.
