Clear History through API?
  • StealthJoe
    • Mar 2019
    • 44
    I want to delete all history of a particular item through the API but I can't seem to find the method to do this.
    Is it possible? I want the same functionality as "Clear History and Trends" that you find on the item page in the frontend.
    Thanks!
  • StealthJoe
    • Mar 2019
    • 44
    Couldn't find anything about this, really doesn't seem like it's possible through the API.
    For my application I was able to achieve a similar result by putting my item in a new template and unlinking/linking when I want to clear the history.
