monitoring postgress 12 on ubuntu
  • ilia
    • Dec 2018
    • 37
    I want to monitor A PostgreSQLDB
    I have an ubuntu (lxc based) system with postgress12 i would like to monitor
    i tried different solution's i found online, but none worked..
    can anyone suggest a step by step solution that works?
  • AVP.Riga
    • Oct 2020
    • 59
    This one works perfectly but it's for CentOS, but I don't see any promlem to change dnf to apt-get and change repo links from rhel/centos to ubuntu.
    Use this step-by-step tutorial to install the latest Zabbix 7.0 on CentOS 9 or 8, RHEL 9 or 8, Oracle / Alma / Rocky Linux 9 or 8!
    Also I see there is article version for debian: https://bestmonitoringtools.com/how-...ver-on-debian/
    • AVP.Riga
      • Oct 2020
      • 59
      Part with postgress12 timescaledb you can find there:
      https://techexpert.tips/zabbix/zabbi...-ubuntu-linux/
      I assume you want install with postgress because you want to use timescaledb extension?
      • ilia
        • Dec 2018
        • 37
        i think i was not clear enough ( i just updated my original question )
        i already have a zabbix server 5.2.1 that monitor around 50 various hosts, no i want to monitor a specific PostgreSQL sql DB
        • AVP.Riga
          • Oct 2020
          • 59
          It's not very tricky. You can use built-in template:
          Also you can use agent-less check by ssh commands.
          Like: [root@centos8min2 ~]# systemctl status mysqld.service
          ● mysqld.service - MySQL 8.0 database server
          Loaded: loaded (/usr/lib/systemd/system/mysqld.service; enabled; vendor preset: disabled)
          Active: active (running) since Tue 2020-11-17 09:54:36 EET; 5h 49min ago
          After it you can use preprocessing to clean everything except: active (running) or inactive (dead), after it use Value Mapping to convenient it to more convenient look.
          • ilia
            • Dec 2018
            • 37
            but the template there is yml and not xml,
            • AVP.Riga
              • Oct 2020
              • 59
              Templates already inside:
              Also you can try to use Postrgresql Prometheus exporter with https://www.zabbix.com/integrations/prometheus
              • ilia
                • Dec 2018
                • 37
                i found the template and imported it,
                but when all the items->test return
                • Unsupported item key.
