Missing menu entries in Configuration / Action
  • parcival
    • Sep 2010
    • 44
    Hi there
    lacked a little understanding of actions.
    i miss the option to select a new condition "tags" as a type of calculation or the option to create remote command.
    At the moment i only have this option for "type of calculation".
    Application, Event type, Host group, Template and Host
    How do i get "tags" and "remote commands" in operations ?
    Zabbix version v5.2
    thx for any help here
    parcival
    OK, solution found self.
