Zabbix Server VM - Add a Hard Drive
  • stevefxp
    • Aug 2020
    • 168
    Hello all,
    I have my Zabbix server as a vm, using 32 gig of hard drive space. I would like to add a hard drive, to move the MySQL onto this hard drive? Has anyone done this, and if yes whats the best way to get this done?
    Thanks,
    Steve
    Its more of a Linux(?) question, than Zabbix...
    • patrickdenis
      • May 2020
      • 18
      Originally posted by stevefxp
      Hello all,
      Thanks,
      Steve
      Hi ,
      !st you need to add the HDD to your VM then restart your VM,
      After that depending of your structure ican give you can example :
      df -h lookup what is writtin after /dev/ and replace the words from my example :
      fdisk -l to see if you see you added HDD, lets say for that example that it added sdb and your main hdd ison sda.
      start fdisk /dev/sdb
      u (don't mind the depricated warning)
      n
      p
      (leave all the questions to default answer)
      w
      REBOOT
      pvcreate /dev/sdb1
      vgextend {{VAR1}} /dev/sdb1
      lvextend -l 100%FREE /dev/mapper/{{VAR2}}
      resize2fs /dev/mapper/{{VAR2}}
      VAR1 = run the command pvdisplay and note the name in front of VG Name :
      VAR2 = look at the path/name when you do an df -h
      example : /dev/mapper/ubuntu--vg-ubuntu--lv
      if it is not clear , look up how to add an second HDD to ubuntu in google maybe some can explain it better then me !
