I am new to zabbix. I have a basic requirement of monitoring occurrence of different log messages using zabbix. Say, when there is a log message "server starting", zabbix should show that alert. The idea is that if the server (re)starts 10 times in last 10 minutes, the zabbix dashboard (or at any other place) should display that 10 times.
I have done the following for that :
1. Created an item under template MyTemplate:
Type : Zabbix Agent (Active)
key : log[/opt/mylog/logs/abc.log,server starting]
Type of information : Log
Update Interval (in sec) : 30
2. Created a trigger with expression :
{MyTemplate:log[/opt/mylog/logs/abc.log,server starting].logeventid(1)}=0
With logeventid(1), I am seeing that the alert (trigger) is getting generated only once. It appears only once in the Dashboard --> Last 20 issues. If I go to Monitoring --> Trigger, I see the alert only once, although the log files have 10 entries of the message "server starting" (server restarted 10 times).
Then I set the trigger to following :
{MyTemplate:log[/opt/mylog/logs/abc.log,server starting].nodata(300)}=0
Now, at Monitoring --> Trigger, I see the alert (trigger) 10 times, but, from the Dashboard "Last 20 issues" it vanishes just after 300 seconds.
My questions are :
1. What should be the trigger function, I should use? I want to see 10 alerts in zabbix if the same message appears 10 times in the log file within a period of time.
2. With nodata(300), why does the alert vanish after 300 sec?
3. Is it ok if I use 30 minutes instead of 300 seconds as an argument of nodata()?
My questions are :
