Hi guys,
I am trying to wrap my head around the following problem but I am not able to figure it out.
I configured an item of type "Zabbix trapper" (let's say it's ) and I am able to receive the data from an external (3rdparty) application which sends me a JSON with the following format:
I would like to set a trigger (or triggers) in a way that:
Question 1: Is it a good idea to keep the JSON as item value or should I apply some preprocessing? Please note, that I would like to use JSONPath in both trigger name and expression, but it seems impossible - as only macros like {ITEM.VALUE} are supported
Question 2: Or should I better create dependent items (id, tenant, message) which use JSONPath preprocessing to grab the particular info and then construct multi item trigger?
Question 3: For severity, is there a chance to create one "dynamic" trigger which grabs the severity from the item - or do I have to crete multiple triggers (per severity) which match the severity in json?
Any info/answers/hints will be highly appreciated!
system: "system-23",
status: "Error",
issue: {
tenant: "tenant-1",
severity: "Warning",
message: "XZ-2546 - no data in last 1 hour"
- I can reuse the detected severity (it follows 1:1 the zabbix severity)
- it has a name constructed out of the json, possibly using JSONPath - e.g. "tenant-1 | XZ-2546 - no data in last 1 hour"
- allows multiple events (tagged with the $.issue.id)
