does anyone even reads topics here?!?!?
  • 1bsot
    • Nov 2020
    posted a problem here a week or so about regular expression that doesn't work and got one respond that got me no where.
    I am trying to filter unnecessary events regarding services that are not important like BITS etc.
    It seems nothing I put in the filter doesn't actually filter the events.
  • yurtesen
    • Aug 2008
    • 130
    Unfortunately this forum is not as active as some other forums I have been to. But people do read and respond to questions yes
    • Hamardaban
      • May 2019
      • 2714
      No one answered your question because no one is interested in it!
      Everything you ask is described in the documentation and has been repeatedly discussed on the forum and on the Internet.
      What doesn't work for you is most likely the result of your misunderstanding or errors during configuration.
      Read the documentation and try to figure it out. Good luck!
      • 1bsot
        1bsot commented
        every thing you suggested was already done - still no change. thanks for your answer any way.
      People answer questions here out of their own free will and time... There is no guarantee that any proposed solution works for you. Pay for support and get your questions answered by official support, that way you can be sure, you get a working solution.
