Zabbix frontend Error connecting to database
  • lulitalee
    • Nov 2020
    Hello everyone,
    I'm having a problem at zabbix web interface, it won't connect to the database as I receive this error: Error connecting to database. Here are two screenshots from both files:
    /etc/zabbix/zabbix_server.conf
    /usr/share/zabbix/conf/zabbix.conf.php.example
    Let's help me fix it! Thanks!
  • tim.mooney
    • Dec 2012
    • 1432
    Did you follow the instructions to set up the front end, https://www.zabbix.com/documentation...ation/frontend
    One of the steps is to download the generated zabbix.conf.php and then copy it into place in zabbix/conf/zabbix.conf.php
    If you only have zabbix.conf.php.example in that directory, then you haven't completed the installation of the front end.
