Hi all,
a very newbie question:
I have a trigger raised from an snmp switch monitoring that controls status changes on every interface.
My question is: why after a few seconds the trigger is activated ( with status PROBLEM ), it automatically changes to status OK?
Is there a way to avoid this? ( for example, changing the status only after
trigger acknowledgment, or only after the problem is solved)
Thanks in advance for your help
Cristiano.
Cristiano.
