Hello all, I'm new to Zabbix and I have a problem that I need some help with.
I want to monitor files that are older than 30 minutes in a directory. I'm thinking of using this command:
In the agent conf file, I've added this:
This is for my item:
- This refreshes every 30s.
For the Trigger, I used this:
Zabbix is sending out alerts but it resolves itself after 4-5 minutes even if the files are still in the directory. I was expecting that it will only send out resolution alerts if and when it doesn't see any files in the directory anymore. What am I missing?
Appreciate any help I can get!
Thanks!
# find /lvm_encrypted_dir/sftp/*/incoming ! -newermt '30 minutes ago' | wc -l
UserParameter=sftp.check.older30mins,/bin/find /lvm_encrypted_dir/sftp/*/incoming ! -newermt '30 minutes ago' | wc -l
Key: sftp.check.older30mins
{<SERVERNAME>:sftp.check.older30mins.last(300)}>0
Thanks!
