Hi
Can someone help with monitoring the availability of devices on a remote site behind a zabbix proxy.
if i use an item zabbix[host,snmp,available] and a trigger {device:zabbix[host,snmp,available].nodata(10m)}=1 it works fine for remote routers that it connects to and if it doesnt connect it will show as unavailable from the trigger.
I cannot find a way to detect if a proxy is down, or the devices behind the proxy the trigger shows as OK even though no data is received
Chris
Chris
