Display sum button in dashboard
  • piti87
    • Jun 2020
    • 23
    Hello!
    Zabbix 4.4.5
    I want to display a button on the start dashboard.
    This button should be display the actual sum of the Tomcat-Sessions over all Systems.
    The tomcat-sessions will be available for each system.
    My question is, how can i create such a button. No Graph
    Like this
    | Sessions Overall |
    | <counter> |
    Which widget type is the right one for this requirement?
    Like the presentation of the widget "problems by severitiy" or the widget "Host availability"
    Best regards!
  • piti87
    • Jun 2020
    • 23
    thanks!
    any idea for a similar solution?
    no graphic only a infobox, text eg
    • Hamardaban
      • May 2019
      • 2714
      You can change the frontend code as you like.
      OR
      write your own widget.
      OR
      use module https://www.zabbix.com/documentation...manual/modules
        There is no such widget.
