How to mark an interface as not important?
  • twolgemuth
    • Apr 2020
    How do I mark a switch interface as not important? I see in the description it says "2. {$IFCONTROL:"10"}=1 - user can redefine Context macro to value - 0. That marks this interface as not important. No new trigger will be fired if this interface is down.". But I am not seeing where a redefine the Context macro to 0. I am using Zabbix 5.0.5
  • Hamardaban
    • May 2019
    • 2714
    You may not have this macro defined , so create it.
    • JackoAC
      • May 2023
      • 35
      I'm going to revive this post.
      I've read the documentation but I'm having trouble getting the desired result.
      I modify the macro at the host level but all the interface triggers are defined as "not important".
      Can someone explain further how to do it ?
      I'm running on Zabbix 6.0​.
      I want to make this interface on "not important"
      Thank in advance !
      • troffasky
        • Jul 2008
        • 639
        If you just set {$IFCONTROL} to 0 then yes, all interfaces on that host will not trigger on down.
        For one specific interface then you need to create a macro like
        {$IFCONTROL:"ifname"}
        on the host so that only ifname is affected.
