Zabbix Upgrade on Ubuntu 16.04.6 LTS from 4.2.8 to 5.0 LTS
  • vai
    • Jan 2020
    • 12
    I would like to upgrade Zabbix Server from 4.2.8 to 5.0 LTS.
    Zabbix server 4.2.8 is running on Ubuntu 16.04.6. And In order to upgrade to 5.0 LTS, we need to upgrade OS to Ubuntu 18.04. However if we upgrade OS then it removes existing Zabbix Server 4.2.8.
    Can you please help me to address the issue in upgrading Zabbix server without loosing data?
    I have tested Zabbix DB backup & restore from 4.2.8 to 5.0 but it does not shows all the data in GUI.
    Thank you.
  • Atsushi
    • Aug 2013
    • 2028
    Did you start the new version of Zabbix server daemon after the restore and confirm that the database upgrade process completed successfully? If you get any error message, please tell me what it is.
    • vai
      • Jan 2020
      • 12
      I started the new version of Zabbix after restore and accessed the frontend.
      Please see below error messages which I encountered while performing the restore. Which are mainly related to DB dependencies.
      But I am keen to know how can we upgrade without DB restore?
      ERROR 1005 (HY000) at line 3: Can't create table `zabbixdb`.`httpstep_field` (errno: 150 "Foreign key constraint is incorrectly formed") + mysql zabbixdb
      ERROR 1005 (HY000) at line 3: Can't create table `zabbixdb`.`httpstepitem` (errno: 150 "Foreign key constraint is incorrectly formed") + mysql zabbixdb
      ERROR 1005 (HY000) at line 3: Can't create table `zabbixdb`.`httpstep` (errno: 150 "Foreign key constraint is incorrectly formed")+ mysql zabbixdb
      ERROR 1005 (HY000) at line 3: Can't create table `zabbixdb`.`httptest_field` (errno: 150 "Foreign key constraint is incorrectly formed") + mysql zabbixdb
      ERROR 1005 (HY000) at line 3: Can't create table `zabbixdb`.`httptestitem` (errno: 150 "Foreign key constraint is incorrectly formed") + mysql zabbixdb
      ERROR 1005 (HY000) at line 3: Can't create table `zabbixdb`.`httptest` (errno: 150 "Foreign key constraint is incorrectly formed")
      • Atsushi
        • Aug 2013
        • 2028
        What was the specific procedure for backing up and restoring? Did you restore only the old database to an empty database in the new environment?
        • vai
          • Jan 2020
          • 12
          We restored the using mysqldump and we restored old database to an empty database.
