Can not connect to remote mysql database with zabbix
  • ptera
    • Oct 2014
    • 109
    I have two servers connected together with a direct connection on a private subnet.
    I can connect to the mysql from the zabbix server from console.
    [root@zabbix ~]# mysql -u zabbix -p -h 10.64.64.2
    Enter password:
    Welcome to the MySQL monitor.  Commands end with ; or \g.
    Your MySQL connection id is 5
    Server version: 5.1.73 Source distribution
    Copyright (c) 2000, 2013, Oracle and/or its affiliates. All rights reserved.
    Oracle is a registered trademark of Oracle Corporation and/or its
    affiliates. Other names may be trademarks of their respective
    owners.
    Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
    mysql>
    But when I try to connect zabbix...
    22216:20150429:093013.356 [Z3001] connection to database 'zabbix' failed: [2003] Can't connect to MySQL server on '10.64.64.2' (13)
    22216:20150429:093013.357 database is down: reconnecting in 10 seconds
    Here is the config...
    ### Option: DBHost
    DBHost=10.64.64.2
    DBName=zabbix
    DBUser=zabbix
    DBPassword=**********
    Is an actual hostname lookup required?
    What am I missing?
  • ptera
    • Oct 2014
    • 109
    MYSQL permissions
    USER
    zabbix localhost *DC7B36BF0104C0689E7194EDACD91E6A96536DB2 None None
    zabbix 10.64.64.0/24 *DC7B36BF0104C0689E7194EDACD91E6A96536DB2 None None
    DATABASE
    zabbix zabbix 10.64.64.0/24 All
    zabbix zabbix localhost Select | Insert | Update | Delete | Create | Drop | References | Index | Alter | Create temp | Lock | Create View | Show View | Create Routine | Alter Routine | Execute | |
    No HOST PERMISSIONS
    I tried adding host permission but there was no change.
    • ptera
      • Oct 2014
      • 109
      remotely logged in...
      mysql> SHOW GRANTS FOR 'zabbix'@"10.64.64.1";
      | Grants for [email protected] |
      | GRANT USAGE ON *.* TO 'zabbix'@'10.64.64.1' IDENTIFIED BY PASSWORD '*DC7B36BF0104C0689E7194EDACD91E6A96536DB2' |
      | GRANT ALL PRIVILEGES ON `zabbix`.* TO 'zabbix'@'10.64.64.1' WITH GRANT OPTION |
      2 rows in set (0.00 sec)
      • ptera
        • Oct 2014
        • 109
        bit by selinux
        Geesh it was still enabled on the server!
        Disabled and rebooted - problem solved
