Zabbix - Monitoring MySQL using ODBC template, server keep crashing
  • mantonik
    • May 2015
    • 17
    Hi
    I setup latest version of zabbix server 5.2 2 on Linux Oracle server 8.
    I want to monitor MySQL database.
    I setup ODBC and configure host using template MySQL ODBC.
    I have only
    Zabbix Server
    MySQLDB
    Only two hosts
    if MySQL DB host is disabled then Zabbix server is working, soon as I enable MySQL database Zabbix server keep crashing.
    With Zabbix 4.x ( I am using this on another server) I set up a proxy server with Postgres to monitor the MySQL database. I read somewhere that the Zabbix server or proxy can't monitor MySQL when they using MYSQL as their own database.
    Is this still a valid statement?
    Log sample when it start crash
    55976:20201210:210139.846 End of am_db_flush_results() flushed:0
    55976:20201210:210139.846 zbx_setproctitle() title:'alert syncer [queued 0 alerts(s), flushed 0 result(s) in 0.001836 sec, idle 1 sec]'
    55965:20201210:210139.846 End of am_flush_results()
    55965:20201210:210139.846 In zbx_ipc_service_recv() timeout:1
    55953:20201210:210139.847 Got signal [signal:11(SIGSEGV),reason:128,refaddrnil)]. Crashing ...
    55953:20201210:210139.847 ====== Fatal information: ======
    55953:20201210:210139.847 Program counter: 0x7fbd1516d64f
    55953:20201210:210139.847 === Registers: ===
    55953:20201210:210139.847 r8 = 559c5e568a00 = 94130085988864 = 94130085988864
    55953:20201210:210139.847 r9 = 7fffb1c42718 = 140736175810328 = 140736175810328
    55953:20201210:210139.847 r10 = f = 15 = 15
  • mantonik
    • May 2015
    • 17
    I set up a proxy server using zabbix-proxy posgress and used that proxy server to monitor mysql db.
    With proxy system is working as expected.
    • Hamardaban
      • May 2019
      • 2714
      Look at this - it says what your problem is
      https://www.zabbix.com/documentation...es#odbc_checks
      MySQL unixODBC driver should not be used with Zabbix server or Zabbix proxy compiled against MariaDB connector library and vice versa, if possible it is also better to avoid using the same connector as the driver
