Monitoring HP MSA 2040
  • sphtd7
    • Dec 2020
    • 52
    Hi, do you know if it is possible, if so, how to monitor the HP MSA 2040 in Zabbix?
    I found one solution, but I don't know if it works on the latest version Zabbix.
  • Hamardaban
    • May 2019
    • 2714
    The Zabbix Team has collected all official Zabbix monitoring templates and integrations.
    Делюсь полезным шаблоном для мониторинга СХД HP MSA 2040 и HP MSA 2050. В шаблоне 580 элементов данных и 716 триггеров. Работает на основе получаемых от СХД SNMP traps.
    • sphtd7
      • Dec 2020
      • 52
      Yes, I tried to do it, when I already add the template and the host, it shows errors like this. I dont know what to do next
      • Alex_Lex
        • Jul 2020
        HI sphtd7
        did you solve this problem?
        • sphtd7
          • Dec 2020
          • 52
          Originally posted by Alex_Lex
          HI sphtd7
          Hi!
          Unfortunately not
          • Alex_Lex
            • Jul 2020
            sadly, I have such a problem now
            • sphtd7
              • Dec 2020
              • 52
              Alex_Lex the author of the plugin, unfortunately, has not responded to e-mail for several months. If you find another solution or you manage to fix it, please let me know!
              • sphtd7
                • Dec 2020
                • 52
                • Alex_Lex
                  • Jul 2020
                  in my case the problem arose after updating the zabbix server, temporarily rolled back to the old version zabbix 5.2.6
                  • sphtd7
                    • Dec 2020
                    • 52
                    Alex_Lex Leave this template, I struggled with it for too long .. I found another one where installation takes 5 minutes maximum and is very easy. Follow the instructions step by step and you will succeed!
                    https://share.zabbix.com/storage-dev...DozjNkN3ONndVo
                    • lmonasterio
                      lmonasterio commented
                      Hi sphtd7 Is it working your solution? I have zabbix 5.0 and i need to monitor HP P2000 storage. Thanks!
                  • Alex_Lex
                    • Jul 2020
                    @sphtd7
                    very grateful!
                    one of these days I will try this option
                    • Alex_Lex
                      • Jul 2020
                      maybe someone saw there is a solution for MSA 2060, please let me know thanks
