Here's the behavior I'm seeing when using network discovery using SNMP:
Note, if a host has its SNMP off and it has never been in Zabbix, it doesn't get discovered as expected.
- A host is added to Zabbix when it's found via SNMP (works well)
- I turn off SNMP on the host and delete the host from Zabbix
- Zabbix re-discovers the host again. The SNMP of the host is marked red, but it's still re-inserted into Zabbix
