net.if.in[eth0,bytes] not supported
  • Plepple
    • May 2015
    I'm getting this error message in the agent's log file
    active check "net.if.in[eth0,bytes]" is not supported
    I'm running the agent on a Windows virtual machine (NAT mode), server on Redhat 6 virtual machine, and I renamed the network interface in Windows to "eth0", restarted both the agent and server, and still the same issue persists. The passive checks are all working.
    Any ideas?
