Fortinet 600D Firewall not able to connect to Zabbix server on via SNMP.
  • zeeshanopel
    • Dec 2020
    We have a Fortinet 600D firewall which is not able to communicate with Zabbix server via SNMP. However older Fortinet firewalls were able to connect. Please help.
  • LenR
    • Sep 2009
    • 1008
    On the server (or proxy) monitoring the new firewall, debug with snmp command line utilities. You'll have to verify the firewall config, is there a whitelist? Community name? "firewall rule"? Until it works from the command line, it's not a Zabbix problem.
    • zeeshanopel
      • Dec 2020
      I am able to ping the firewall from the zabbix server however not able to telnet on port 161. What can i do to resolve the issue?
      • Martin Jørgensen
        • Feb 2020
        • 10
        HI
        I will recommend to resolve the connections issue on your firewall.
        • irshad
          • Dec 2020
          SNMP over port 161 is typically UDP based, you cannot reliably check the status via a tcp based protocol (telnet), do an snmpwalk or snmpget and see if the firewall responds to the requests.
