Can I add an alert script from an external location?
  • cesarsj
    • Dec 2018
    • 154
    Because the ZBX server cannot have access to the internet, and we want to trigger an alert script from another server that has free access.
  • LenR
    • Sep 2009
    • 1010
    An action could be configured to run a command on the server with the access. https://www.zabbix.com/documentation...remote_command
    • cesarsj
      • Dec 2018
      • 154
      It would be a great solution if it were possible to pass macros on the remote. I left:
      /opt/zabbix-hangout.sh {ALERT.SUBJECT} {ALERT.MESSAGE} and the Zabbix Agent on the remote server is literally getting this.
      • LenR
        • Sep 2009
        • 1010
        I pass {HOST.HOIST} in an auto registration action. There was a list of where you could use which macro's, but I can't find it at the moment.
        • cesarsj
          • Dec 2018
          • 154
          I just saw that only the {ALERT.SUBJECT} and {ALERT.MESSAGE} macros do not work, the others work on the command. Your great solution helped me!
          • LenR
            • Sep 2009
            • 1010
            Odd, what version of Zabbix?
            • cesarsj
              • Dec 2018
              • 154
              The version is 4.0.26
