Change traffic graphs display value
  • Giacomo
    • Dec 2020
    • 14
    Hi All,
    I want to set my network traffic graphs to display "maximum" and not "average".
    I can go inside the items but the field it's gray, so it's not possible to change.
    Any help?
    Thanks!
  • Atsushi
    • Aug 2013
    • 2028
    If the graph is generated by a template or a discovery rule in a template, try changing the contents set in the template or the discovery rule in the template.
    • Giacomo
      • Dec 2020
      • 14
      Hi!
      Thanks for the answer.
      I was able to set "max" on the item, but still I don't see the right value in Mbps on my graphs.
      I've made a network speed test on the link and I see on the graph 24Mbps/13Mbps, when my test result was 80Mbps/20Mbps.
      Where is the issue?
