Nested templates issue with http agent checks
  • nkastanas
    • Apr 2020
    need some help on this, i can not found any documentation online.
    Template A owns an item A (http agent)
    Template B linked to Template A
    Its impossible to disable this item in Template B.
    If the item type is zabbix agent, trapper, passive, active works fine.
    it always returns
    Cannot disable item
    • Invalid parameter "/interfaceid": cannot be empty.
    I did try with Zabbix 5.02 5.05 and 4.4, also if item is disabled in Template A, then cant enable it in Template B
    any help will be appreciated
    Thank you
  • nkastanas
    • Apr 2020
    admin please move it to Zabbix Troubleshooting and Problems
