Which macro???
  • roberdaniel
    • Apr 2019
    • 22
    Which macro???
    Hi all
    I would like to send notifications with an error text as you can see here
    I've tried various macros with no luck at the moment.
  • roberdaniel
    • Apr 2019
    • 22
    Thank you cyber I will try that approach.
    Regards.
      • 4993
      No macro for that. That value is stored in item "Last error message of scenario <Scenario>", use it to construct your trigger name.
      https://www.zabbix.com/documentation...nitoring/items
