host.create fails
  • hfk
    • Nov 2020
    host.create fails
    I am trying to create a new host using the API. I am able to get information about an existing host, about maintenance groups, periods and more, but I get an error when I try to create the host.
    $API_Host_Create = @{
    jsonrpc = "2.0"
    method = "host.create"
    params = @{
    host = "presaprsa2002v"
    interfaces = @{
    type = "1"
    main = "1"
    useip = "1"
    ip = "10.163.121.92"
    dns = "presaprsa2002v.xyz.com"
    port = "10050"
    groups = @{
    groupid = "1085"
    templates = @{
    templateid = "24774"
    auth = "$($auth_session)"
    id = 1
    function ESA_ZBX_HostCreate($hg_id, [boolean]$action, $ZAPI_Site)
    $auth = zabbix_api($API_Login)
    $auth_session = ($auth.result)
    $API_Host_Create.auth = $auth_session
    if ($auth.result)
    #$($API_Host_Create | ConvertTo-Json) | out-file hanscreate.json
    $zhostcreate = zabbix_api($API_Host_Create)
    $hostcreate_error = $zhostcreate.error
    $hostcreate_result = $zhostcreate.result
    return $hostcreate_result.result
    $Test = ESA_ZBX_HostCreate $DCE_SVS_id $true $DCE_A
    NB! The parameters are not used at this moment.
    Create result: @{code=-32500; message=Application error.; data=No permissions to referred object or it does not exist!}
    I would very much appreciate suggestions on how to solve the problem. I am using Zabbix 4.4.
    Thank you very much
  • LenR
    • Sep 2009
    • 1010
    Maybe the account used to login to the API doesn't have enough permission to create a host.
    • hfk
      hfk commented
      If I use my "admin-account" I can create a host from the normal Zabbix-GUI. If I use the "admin-account" in the script it fails. My "Zabbix-Admin" tells me I have the necessary rights, but I agree with you that it sure looks "fishy".
  • LenR
    • Sep 2009
    • 1010
    I use https://github.com/lukecyca/pyzabbix so I don't have to mess with the lower level API stuff, but since we auto register hosts, I have never scripted a host.create. Our network team does, they used Perl in the past, not sure what they use not, but I don't ever see their code.
    • hfk
      • Nov 2020
      Problem solved. I use PowerShell and the json-object had to be rewritten in a way PowerShell could understand.
      eg.
      groups = @(@{
      groupid = "1085"
      When I corrected this in the definition of the object everything began working.
      In the function Zabbix_api($body) I put in a line "write-host $bodyJson" to see what the object transferred really looked like. This gave a good clue.
      Thank you for answering and helping me here.
