Is possible zabbix send data to elasticsearch
  • Psjganesh
    • Dec 2020
    Is possible to send zabbix data to elasticsearch. If possible please provide the steps
  • Psjganesh
    • Dec 2020
    Please update on this query
    • LenR
      • Sep 2009
      • 1011
      Yes, but your question isn't really clear.
      There is this https://www.zabbix.com/documentation...c_search_setup that stores history on elasticsearch, it's "Experimental". I don't think this would be easily queried in elasticsearch
      I have created elasticsearch queries that run as cronjobs, sending data with zabbix_sender, with triggers defined for alerting. I find this easier for me than the Watcher functions, mainly because Zabbix was already integrated with our on-call rotation system. I've also used userparameters instead, either work, but some queries may risk timeout failures as userparameters.
      • Psjganesh
        • Dec 2020
        Thanks for update. I have visualisze zabbix data on kibana dashboard is it possible?
        • Psjganesh
          • Dec 2020
          Please update is there any possible to visualize zabbix data using kibana
