Hi. I am writing a telegram-bot on PHP, which should receive from Zabbix via API a list and number of Problems that do not have a "acknowledged" state and whose severities is from 4 to 5, including 5.
I can easily get such a list in the web interface at
= i get 10 Problems
But if I make a request to the API such as this
in response I get 442 Problems.
Please help me understand why there is such a difference in the result? What am I doing wrong?
Thank you.
https://localhost/zabbix.php?action=problem.view&filter_show=3&filter_application=&filter_name=&filter_severities%5B4%5D=4&filter_severities%5B5%5D=5&filter_inventory%5B0%5D%5Bfield%5D=type&filter_inventory%5B0%5D%5Bvalue%5D=&filter_evaltype=0&filter_tags%5B0%5D%5Btag%5D=&filter_tags%5B0%5D%5Boperator%5D=0&filter_tags%5B0%5D%5Bvalue%5D=&filter_show_tags=3&filter_tag_name_format=0&filter_tag_priority=&filter_show_opdata=0&filter_unacknowledged=1&filter_set=1
"jsonrpc": "2.0",
"method": "problem.get",
"params": {
"acknowledged": "0",
"severities": ["4","5"],
"suppressed": "0"
"auth": "__auth_key__",
"id": 1
Thank you.
