Run remote command on trigger
  • rocklee44
    • Apr 2015
    Hi all,
    I'm using Zabbix 2.4 to monitor nodejs service on a server, I want Zabbix Agent can restart service when trigger on "service down"
    /etc/passwd
    zabbix:x:498:498:Zabbix Monitoring System:/var/lib/zabbix:/sbin/nologin
    I want Zabbix agent can run this command as userA:
    /path-to/forever restart /path-to/nodejs.js
    How should I configure action : Target list , Type , Commands
    And visudo ?
    Thanks for your help.
  • rocklee44
    • Apr 2015
    Can anyone help me ?
    • Atsushi
      • Aug 2013
      • 2028
      If you want execute that command line by userA, you must settng change shell and visudo.
      At first, you must change shell for zabbix user.
       # usermod -s /bin/sh zabbix
      Next, some setting change by visudo.
      Add 2 lines :
      zabbix ALL=(userA) NOPASSWD:/path-to/forever restart /path-to/nodejs.js
      Defaults:zabbix !requiretty
      And, EnableRemoteCommands value set to 1 in zabbix_agentd.conf.
      EnableRemoteCommands=1
      After that, you can add Action setting.
      example value:
      Operation type : Remote command
      Type : Custom script
      Execute on : Zabbix agent
      Commands : sudo -u userA /path-to/forever restart /path-to/nodejs.js
      • kloczek
        • Jun 2006
        • 1771
        You can add top of the trigger action (Configuration -> Action -> triggers)
        In Action definition Trigger name and exact template or host name and in Operations tab: Operation type -> Remote command and here you can choose execute action on zabbix agent or server.
        To be honest I think that it would be good if it would be possible to define actions on template/host level as well.
        • rocklee44
          • Apr 2015
          Thank you very much Atsushi,
          I made it worked.
          • pangarano
            • Apr 2015
            • 9
            Thank you, this is useful I'll try to implement it
