JMX Authentication
  • eduardlh
    • Jan 2012
    JMX Authentication
    Hello there!
    I need your help to know how to add jmx credentials on Zabbix. I try to monitor a JVM with authentication but Zabbix-Java-Gateway told me this:
    (please see the attached file) I can not post the log, sorry
    I haven't any template attached from this host, I only add jmx interfaces and port.
    I try to set up JMX credentials with macros {$USERNAME} {$PASSWORD} or {$USER} {$PASS} or {$NAME} {$PASSWORD}.
    Nothing works
  • BDiE8VNy
    • Apr 2010
    • 680
    It doesn't matter which user macros you use. Just ensure you use them in the respective JMX items.
