I've installed the latest version of Zabbix successfully on EC2 and trying to upload data from a pfSense installation.
I would like it to be active so that I wouldn't need a static IP for my pfSenseinstallation.
I have configured a new host in Zabbix, with no template and no interface (as it should be active) and installed the agent on my pfSenseinstallation. configured the URL of my Zabbix instance + port 10051.
I have a few questions:
1. If this should be an active agent, why do I need to configure the Zabbix 'Server' shouldn't it be only the 'Server Active'?
2. I don't see any new data on my Zabbix installation. Any idea how can I debug it? the pfSense logs show the following with no errors and the host name is the same in both configurations. The Ec2 installation is visible and all ports are open (for now)
79770:20210102:190128.653 Starting Zabbix Agent [xxx.xxxx]. Zabbix 5.2.0 (revision bcf99fb248).
79770:20210102:190128.653 **** Enabled features ****
79770:20210102:190128.653 IPv6 support: YES
79770:20210102:190128.653 TLS support: YES
79770:20210102:190128.653 **************************
79770:20210102:190128.653 using configuration file: /usr/local/etc/zabbix52/zabbix_agentd.conf
79770:20210102:190128.653 agent #0 started [main process]
79780:20210102:190128.653 agent #1 started [collector]
80067:20210102:190128.653 agent #2 started[listener #1]
80090:20210102:190128.653 agent #3 started[listener #2]
80248:20210102:190128.653 agent #4 started[listener #3]
80540:20210102:190128.654 agent #5 started [active checks #1]
