Conditions: Trigger Value missing in v5
  • Tariq Hasan
    • Nov 2018
    • 27
    Hi All
    Conditions: what is the equivalent in v5.x to "Trigger Value" in v3.x? It doesn't seem to appear in the dropdown list in 5 in Configuration -> Actions
    Hope you can help, as boy, do I need it!
    Tariq
  • Hamardaban
    • May 2019
    • 2713
    In the upper-left corner of the screen, there is a drop-down list - select “trigger actions” and then you will see what you need
    • Tariq Hasan
      • Nov 2018
      • 27
      Hi
      My query was more specifically about this issue:
      In v3 we could set the condition "Trigger value = PROBLEM" to stop the RECOVERY message coming through, but in v5 there is no "Trigger value" in the drop-down menu Action -> Condition -> Add -> New Condition
      So at the moment we are delaying the HOST DOWN message unless it goes on for a couple of minutes, but want to suppress the associated RECOVERY message.
      Hope this makes sense.
      Regards
      Tariq
      • Hamardaban
        Hamardaban commented
        yes-it's clearer that way.
    • Tariq Hasan
      • Nov 2018
      • 27
      Sorry, I don't understand. Do you have a solution? Do you require any more information from me?
      • Hamardaban
        • May 2019
        • 2713
        For information - this condition is in 3.0 and was removed in the next version 3.2.
        I assume that there are other methods to achieve what you need.
        • Tariq Hasan
          • Nov 2018
          • 27
          There probably are - but I don't know which one replaces the one that was removed, or can achieve the same result.
          • aguiraf@gmail.com
            • Sep 2021
            Did you ever resolved this issue?
            the absence of the condition "trigger value" in the action definition does not permit to NOT send notification when trigger returns in OK state.
