Zabbix auto register action add jmx
  • stephen8339
    • May 2015
    When the host has been registered, how can I let it add the jmx IP and port automaticly?
  • LenR
    • Sep 2009
    • 1011
    create a notification for the registration that uses a media type pointing to a script. In that script, make API calls.
    It would be nice if there were an easier way :-)
    • stephen8339
      • May 2015
      ok, thx a lot, but I want more details about the script and the API calls, can u help me?
      • LenR
        • Sep 2009
        • 1011
        Reviewing what I have in place, I didn't use a media type, but something similar. In the operations of the auto registration action, I have a:
        Run remote commands on hosts: some-host-with-API-enabled (I run where the web frontend is installed), type custom script, execute on zabbix-agent, commands "/etc/zabbix/update_autoreg.py {HOST.HOST1}"
        My sanitized script is below, I'm turning on host inventory, so the calls to add the JMX interface will be different. This is using the pyzabbix api (pip install pyzabbix).
        #!/usr/bin/python
        Set host inventory to automatic.
        from pyzabbix import ZabbixAPI
        import json, sys, time
        #print sys.argv[1]
        time.sleep(5)
        # The hostname at which the Zabbix web interface is available
        ZABBIX_SERVER = 'https://localhost/zabbix'
        zapi = ZabbixAPI(ZABBIX_SERVER)
        # Login to the Zabbix API
        zapi.login('user',' password')
        inv = zapi.host.get(filter={'host':sys.argv[1]},output="extend",selectInventory="extend",limit=4 )
        hostIdValue = inv[0]['hostid']
        hostValue = inv[0]['host']
        invinfo = inv[0]['inventory']
        if len(invinfo) == 0:
        response = zapi.host.update(hostid=hostIdValue,inventory_mode =1)
        • m081072
          • Jun 2015
          Some clarification please....
          What do you mean the calls to add the jmx interface will be different? Are you saying the script needs to add the jmx interface?
          I am trying to do what the OP has asked.
          Thanks,
          Mike.
