Disk Usage Graphic does not seem on Centos 6.10
  • mekselina
    • Dec 2020
    I use ZABBIX server 5.0 LTS, and monitoring centos host
    I can see disk usage info under latest data, but can not see any graphics about disk usage, host monitoring screen i can see other graphics except disk usage.
    Zabbix agent version: zabbix-agent-5.0.7-1.el6.x86_64.rpm (also tried : zabbix-agent-5.0.0-1.el6.x86_64.rpm)
    Client OS version : Centos 6.10 linux 2.6 x86_64 x86_64 x86_64 GNU/Linux
    Template : Template OS linux with zabbix agent
    I can not see disk usage graphic on CENTOS 6.10, but I can do it on CENTOS 7. (on centos 7 every thing works well)
    -I tried to create a new disk-usage graphic but the result was same.
    some items have problem:
    Block devices discovery: scd0: Get stats vfs.file.contents[/sys/block/scd0/stat] 1m 0 Zabbix agent Zabbix raw items Not supported
    Block devices discovery: scd0: Disk write request avg waiting time (w_await) Triggers 1 vfs.dev.write.await[scd0] 1m 7d 365d Calculated Disk scd0 Not supported
    Block devices discovery: scd0: Disk read request avg waiting time (r_await) Triggers 1 vfs.dev.read.await[scd0] 1m 7d 365d Calculated Disk scd0 Not supported
    Block devices discovery: root: Disk write request avg waiting time (w_await) Triggers 1 vfs.dev.write.await[root] 1m 7d 365d Calculated Disk root Not supported
