Changing template does not change host check
  • mattboston74
    • Jan 2021
    I'm new to Zabbix and have searched through the docs and forums but can't find the answer. I've created a couple test hosts and assigned them to Template OS Linux by Zabbix Agent. After testing out some of the alerting, I noticed that the disk checks are set to 80%/90% for alerting. When it hits 80%, we get the warning alert and is Yellow. When it hits 90%, the alert we receive is called "Average" and is Orange.
    Under Templates -> Template Module Linux filesystem -> Discovery rules -> Template Module Linux filesystems by Zabbix Agent Trigger prototypes -> "Disk space is critically low", I updated Severity to be High (dark orange) and clicked Update. What I assume would happen is all hosts that are subscribed to the template, would use the new Severity, but they are all still set to Average.
  • Hamardaban
    • May 2019
    • 2713
    Changes will occur when the LLD rule is triggered and disk systems are "discovered" again.
    • mattboston74
      • Jan 2021
      Ah. I guess that's why when I looked this morning, it was updated. Thank you
