CPU Load average is too high (per CPU load over 1.5 for 5m)
  • voarsh
    • Jan 2021
    Hi.
    I'm new to Zabbix.
    I have a server with 16 CPU cores, and I get a warning for load over 1.5 for 5m - that seems a bit too sensitive for the CPU core count?
    Or am I wrong to be thinking this? If not, how would be the best way to tweak this?
    • 4993
    Default templates? They are there for giving you a quick startup, but they should always be tweaked according to your needs. If this trigger condition seems a bit too much for you, change it according to your needs.
