clear interface down triggers after a certain amount of time.
  • redpeppers
    • Dec 2015
    when using the Template Module Interface Simple SNMPv2. The Interface link down trigger never clears when a specific interface is no longer being used, ie laptop is plugged into a switch for awhile and once its removed that interface triggers show up. Is there a way to have the event clear after a certain amount of time like 5 days. I would rather not manually clear it.
  • Semiadmin
    • Oct 2014
    • 1626
    Problem: net.if.status.last()=2 and net.if.status.diff()=1
    Recovery: net.if.status.last()<>2 or net.if.status.delta(5d)=0
      • 4993
      additional nodata() condition?
