Configure DB connection failing
  • Banni11b
    • Jul 2014
    Am facing problem during DB Test connection (step3), am installed zabbix 2.4 and Mysql 5.6
    The error i got during check is 'Error connecting to database: Can't connect to local MySQL server through socket '/var/lib/mysql/mysql.sock' (13)'.
    The problem am facing is without giving any entry for Db user, DB Password..it will give the same error also.
    Can anyone help me on this...its very urgent for me.
