Help setting up log trigger
  • blastik
    • Sep 2011
    Hi folks,
    I have setup an item like this:
    log["C:\whatever\Logstest.txt",,100]
    But i need help setting up the trigger. I've tried to search around in the forum and also check the documentation but i cannot get it to work. I want to trigger an alert when a trace like the one below is recorded at the log:
    2015-05-15 11:16:23.8370|Error|1556|1|Unregistering errored channel ...
    And reset the trigger status to OK when the following trace comes up:
    2015-05-15 11:10:57.1960|Info|3420|31|Channel whatever started
    Any ideas?
    Thanks a lot!
    D.
  • BDiE8VNy
    • Apr 2010
    • 680
    See Trigger hysteresis
    • blastik
      • Sep 2011
      Originally posted by BDiE8VNy
      So I've tried
      {TRIGGER.VALUE}=0 and {host:log["C:\whatever\Logstest.txt",,100].str(|Error|1556|1|Unregistering errored channel)} or {TRIGGER.VALUE}=1 and {host:log["C:\whatever\Logstest.txt",,100].str(|Info|3420|31|Channel * started)}
      but apparently is not making the trick... Any thoughts?
      • limlayhin
        • Apr 2015
        This is how I do it:
        Item:
        log[/var/log/system.log,"FAILED"]
        Trigger Expression:
        {ServerName:log[/var/log/system.log,"FAILED"].str("FAILED",1)}=1
        But I do not know how to make trigger status to ok.
        • Alex_SYB
          • Feb 2012
          • 133
          Wow, I have just posted a similar question
          How to set the trigger back to OFF
          • BDiE8VNy
            • Apr 2010
            • 680
            One needs to use at least one time-based function within the trigger expression to get a trigger evaluated when no new item value(s) occur.
            See: Zabbix Trigger Timeout
            • Alex_SYB
              • Feb 2012
              • 133
              Hi
              THanks , I will try the nodata addition and see how that goes
