can't upgrade mysql with zabbix
  • majed17
    • Oct 2019
    • 21
    sudo mysql_upgrade -uroot -p --force
    Enter password:
    Phase 1/7: Checking and upgrading mysql database
    Processing databases
    mysql
    mysql.column_stats OK
    mysql.columns_priv OK
    mysql.db OK
    mysql.event OK
    mysql.func OK
    mysql.gtid_slave_pos
    Error : Table 'mysql.gtid_slave_pos' doesn't exist in engine
    status : Operation failed
    mysql.help_category OK
    mysql.help_keyword OK
    mysql.help_relation OK
    mysql.help_topic OK
    mysql.host OK
    mysql.index_stats OK
    mysql.innodb_index_stats
    Error : Table 'mysql.innodb_index_stats' doesn't exist in engine
    mysql.innodb_table_stats
    Error : Table 'mysql.innodb_table_stats' doesn't exist in engine
    mysql.plugin OK
    mysql.proc OK
    mysql.procs_priv OK
    mysql.proxies_priv OK
    mysql.roles_mapping OK
    mysql.servers OK
    mysql.table_stats OK
    mysql.tables_priv OK
    mysql.time_zone OK
    mysql.time_zone_leap_second OK
    mysql.time_zone_name OK
    mysql.time_zone_transition OK
    mysql.time_zone_transition_type OK
    mysql.transaction_registry
    Error : Table 'mysql.transaction_registry' doesn't exist in engine
    mysql.user OK
    Repairing tables
    Phase 2/7: Installing used storage engines... Skipped
    Phase 3/7: Fixing views
    Phase 4/7: Running 'mysql_fix_privilege_tables'
    ERROR 1932 (42S02) at line 635: Table 'mysql.innodb_index_stats' doesn't exist in engine
    ERROR 1243 (HY000) at line 636: Unknown prepared statement handler (stmt) given to EXECUTE
    ERROR 1932 (42S02) at line 638: Table 'mysql.innodb_table_stats' doesn't exist in engine
    ERROR 1243 (HY000) at line 639: Unknown prepared statement handler (stmt) given to EXECUTE
    ERROR 1932 (42S02) at line 643: Table 'mysql.innodb_index_stats' doesn't exist in engine
    ERROR 1932 (42S02) at line 647: Table 'mysql.innodb_table_stats' doesn't exist in engine
    ERROR 1932 (42S02) at line 650: Table 'mysql.innodb_table_stats' doesn't exist in engine
    FATAL ERROR: Upgrade failed
    I tried dropping database zabbix and schema, deleting the idb files in mysql directry, restarting mysql, restoring the database, and then upgrading, with no effect!
    this is happening on centos 8 with zabbix 5
  • yurtesen
    • Aug 2008
    • 130
    This seems to be a bug in MySQL
    https://stackoverflow.com/questions/...s-doesnt-exist
    I would recommend using PostgreSQL in future. It has better performance and you can even use TimescaleDB etc.
    • majed17
      • Oct 2019
      • 21
      now i get:
      Enter password:
      mysql
      mysql.db OK
      mysql.event OK
      mysql.func OK
      mysql.help_topic OK
      mysql.host OK
      mysql.plugin OK
      mysql.proc OK
      mysql.procs_priv OK
      mysql.servers OK
      mysql.time_zone OK
      mysql.user OK
      ERROR 1813 (HY000) at line 77: Tablespace for table '`mysql`.`innodb_table_stats`' exists. Please DISCARD the tablespace before IMPORT
      ERROR 1813 (HY000) at line 81: Tablespace for table '`mysql`.`innodb_index_stats`' exists. Please DISCARD the tablespace before IMPORT
      ERROR 1813 (HY000) at line 85: Tablespace for table '`mysql`.`transaction_registry`' exists. Please DISCARD the tablespace before IMPORT
      ERROR 1813 (HY000) at line 153: Tablespace for table '`mysql`.`gtid_slave_pos`' exists. Please DISCARD the tablespace before IMPORT
      ERROR 1146 (42S02) at line 635: Table 'mysql.innodb_index_stats' doesn't exist
      ERROR 1146 (42S02) at line 638: Table 'mysql.innodb_table_stats' doesn't exist
      ERROR 1146 (42S02) at line 643: Table 'mysql.innodb_index_stats' doesn't exist
      ERROR 1146 (42S02) at line 647: Table 'mysql.innodb_table_stats' doesn't exist
      ERROR 1146 (42S02) at line 650: Table 'mysql.innodb_table_stats' doesn't exist
      i am considering learning posgresql on a separate server, i really those zabbix is the problem as cacti with mysql causes no such problem..
      • yurtesen
        • Aug 2008
        • 130
        This is not a problem related to zabbix. The errors are not even in related to zabbix. There are errors are related to mysql itself. The fact that another mysql installation did not exhibit same problem is probably coincidental. The errors mention mysql's own internal mysql database, nothing to do with zabbix database. It has problems processing mysql.* tables...
        You may have better luck at a mysql forum.
        • majed17
          • Oct 2019
          • 21
          since then i installed a new posgresql server with the same numbers of hosts but now the database is 23G, how to limit that?
