Upgrading from zabbix - Errors cant' figure out what to do.
  • dwoodson
    • Jan 2020
    Hi:
    I was trying to upgrade on the web screen it shows 4.4.10.
    So I followed the upgrade procedure as outlined in https://www.zabbix.com/documentation...es/rhel_centos. I am running centos 7 and it is up to date. I installed php 7.4.14
    Here is a history of what I did:
    [root@monitor ~]# mkdir /opt/zabbix-backup/
    [root@monitor ~]# cp /etc/zabbix/zabbix_server.conf /opt/zabbix-backup/
    [root@monitor ~]# cp /etc/httpd/conf.d/zabbix.conf /opt/zabbix-backup/
    [root@monitor ~]# cp -R /usr/share/zabbix/ /opt/zabbix-backup/
    [root@monitor ~]# cp -R /usr/share/doc/zabbix-* /opt/zabbix-backup/
    [root@monitor ~]# rpm -Uvh https://repo.zabbix.com/zabbix/5.2/r...el8.noarch.rpm
    Retrieving https://repo.zabbix.com/zabbix/5.2/r...el8.noarch.rpm
    Preparing... ################################# [100%]
    Updating / installing...
    1:zabbix-release-5.2-1.el8 ################################# [ 50%]
    Cleaning up / removing...
    2:zabbix-release-5.0-1.el7 ################################# [100%]
    [root@monitor ~]# yum upgrade zabbix-server-mysql zabbix-web-mysql zabbix-agent
    Loaded plugins: fastestmirror
    Loading mirror speeds from cached hostfile
    * base: ftp.ussg.iu.edu
    * epel: mirror.team-cymru.com
    * extras: mirrors.raystedman.org
    * remi-php74: mirror.team-cymru.com
    * remi-safe: mirror.team-cymru.com
    * updates: mirror.genesisadaptive.com
    Resolving Dependencies
    --> Running transaction check
    ---> Package zabbix-agent.x86_64 0:4.4.10-1.el7 will be updated
    ---> Package zabbix-agent.x86_64 0:5.0.7-1.el7 will be an update
    ---> Package zabbix-server-mysql.x86_64 0:4.4.10-1.el7 will be updated
    ---> Package zabbix-server-mysql.x86_64 0:5.0.7-1.el7 will be an update
    --> Finished Dependency Resolution
    Dependencies Resolved
    Package Arch Version Repository Size
    Updating:
    zabbix-agent x86_64 5.0.7-1.el7 zabbix 453 k
    zabbix-server-mysql x86_64 5.0.7-1.el7 zabbix 2.7 M
    Transaction Summary
    Upgrade 2 Packages
    Total download size: 3.2 M
    Is this ok [y/d/N]: y
    Downloading packages:
    Delta RPMs disabled because /usr/bin/applydeltarpm not installed.
    zabbix-agent-5.0.7-1.el7.x86_6 FAILED
    http://repo.zabbix.com/zabbix/5.2/rh...l7.x86_64.rpm: [Errno 14] HTTP Error 404 - Not Found0 B/s | 0 B --:--:-- ETA
    Trying other mirror.
    To address this issue please refer to the below wiki article
    If above article doesn't help to resolve this issue please use https://bugs.centos.org/.
    zabbix-server-mysql-5.0.7-1.el FAILED
    http://repo.zabbix.com/zabbix/5.2/rh...l7.x86_64.rpm: [Errno 14] HTTP Error 404 - Not Found 0 B --:--:-- ETA
    Error downloading packages:
    zabbix-agent-5.0.7-1.el7.x86_64: [Errno 256] No more mirrors to try.
    zabbix-server-mysql-5.0.7-1.el7.x86_64: [Errno 256] No more mirrors to try.
    I am not sure what I should do at this point. I'd hate to restart from scratch as I did some valuable work.
    Any help is greatly appreciated.
    Thank you,
    David
  • yurtesen
    • Aug 2008
    • 130
    You installed rhel8 repository and you are using rhel7. That could be your problem.
      Not just "could be" but is.. You can upgrade to 5.0 on RH (centos) 7, but for anything above, you need 8.
