I upgraded from 5.0.1 to 5.2.3 on CentOS 8 with no issues.
I am seeing feedback from various SNMP devices, but nothing from any Zabbix agent host (other than the server). This holds true for local hosts as well as those connecting from remote sites via zabbix_proxy.
I can see the communication in the proxy server logs for the remote devices: "received configuration data from server at "douganconsulting.com", datalen 4221" and from the agent log on local systems: "active check configuration update from [192.168.150.3:10051] is working again".
However, when I look at any of the hosts, there is no data displayed. I installed the Windows agent (not agent2) on a server at a new location yesterday (which already has the zabbix_proxy active) and it does not show in the list of hosts. I have network discovery active and that is showing the various IP addresses it has seen at that location.
I'm a bit lost - it appears to be working, but the lack of agent data clearly shows it is not. It was working prior to upgrading.
Where can I start looking?
Thanks for any thoughts and suggestions.
Des
Des
