Package error systemd
  • Sherasy
    • May 2015
    Good Morning Partner
    When installing zabbix sevice (Amazon linux) i got the following error:
    Error: Package: zabbix-agent-2.2.9-1.el7.x86_64 (zabbix) Requires: systemd
    install systemd
    error persists
    anyone knows how is solved
    thanks
  • Atsushi
    • Aug 2013
    • 2028
    Please try version for el6.
    But, Newer Amazon Linux use Apache HTTP Server 2.4 by default.
    Then, You must change access control in /etc/httpd/conf.d/zabbix.conf
    Files zabbix-web24.conf in the source package(zabbix-2.2.9-1.el7.src.rpm) will be helpful.
    How to take out:
    $ wget http://repo.zabbix.com/zabbix/2.2/rh...-1.el7.src.rpm
    $ rpm2cpio zabbix-2.2.9-1.el7.src.rpm |cpio -id
