Help with aggregating prometheus metrics
  • colin_leroy
    • Jan 2021
    I'm writing a template based on a Prometheus exporter (Micrometer).
    I'm having difficulties with some items that generate lots of metrics. I'm only interested in totals, but I can't seem to figure a way to do it. For example, the http requests counters exported represent one metric per URI, status code, method, etc :
    # HELP http_server_requests_seconds
    # TYPE http_server_requests_seconds summary
    http_server_requests_seconds_count{exception="None ",method="GET",outcome="SUCCESS",status="200",uri= "/actuator/prometheus",} 10.0
    http_server_requests_seconds_count{exception="None ",method="GET",outcome="SUCCESS",status="200",uri= "/doit",} 19.0
    http_server_requests_seconds_count{exception="None ",method="GET",outcome="SUCCESS",status="200",uri= "/**/favicon.ico",} 1.0
    http_server_requests_seconds_count{exception="None ",method="GET",outcome="CLIENT_ERROR",status="404" ,uri="/**",} 1.0
    I would like the total of http_server_requests_seconds_count.
    If I create a Dependant item (depending on the master Prom item), and preprocess it using "Prometheus pattern" "http_server_requests_seconds_count", I get "cannot apply Prometheus pattern: data extraction error: multiple matching metrics found:"
    Which is true. I've tried promql syntax like sum(http_server_requests_seconds_count) but it's not supported. I can only figure out two solutions, none of which seem clean to me:
    • I can use a Discovery rule with item prototypes, get all those metrics into items, then add an item aggregating those with a grpsum[] function. I don't really want to do that because that would have Zabbix track hundreds of items and that wouldn't be very scalable.
    • I can preprocess using Javascript and implement a very ugly hack, splitting the whole Prom item by line, space and '{' with such a function. I don't really want to do that either because well, it's really ugly :
    var lines = value.split('\n');
    var total = 0.0;
    for (var i = 0; i < lines.length; i++) {
      var fields = lines[i].split(' ');
      var root_field = fields[0].split('{');
      if (root_field[0] == "http_server_requests_seconds_count")
        total += parseFloat(fields[1]);
    return total;
    Is there another, cleaner solution that I'm not aware of?
    Thanks in advance,
    Colin
  • Semiadmin
    • Oct 2014
    • 1626
    Preprocessing steps:
    1. Prometheus to JSON: http_server_requests_seconds_count
    2. JSONPath: $..value.sum()
    • colin_leroy
      • Jan 2021
      Thanks a lot, this makes much more sense I knew I was missing something!
