Operation type only have two items
  • towerx
    • Jan 2021
    • 14
    5.2.3 action \operations
    Send message
    Remote command
  • towerx
    • Jan 2021
    • 14
    is it zabbix or my installation issue? anyone saw that?
    • Hamardaban
      • May 2019
      • 2714
      Please read the documentation!
      You can define the following operations for all events:
      • send a message
      • execute a remote command (including IPMI)
      For discovery and autoregistration events, there are additional operations available:
      • add host
      • remove host
      • enable host
      • disable host
      • add to host group
      • remove from host group
      • link to template
      • unlink from template
      • set host inventory mode
      • towerx
        • Jan 2021
        • 14
        thank you.
        yes, that's what i need, but why i can't see them? how may I "enable" these options, my drop down only have two???
        • add host
        • remove host
        • enable host
        • disable host
        • add to host group
        • link to template
        • towerx
          • Jan 2021
          • 14
          Originally posted by cyber
          Thank you!
            Again... by reading documentation...
            https://www.zabbix.com/documentation...cations/action
            CONFIGURING AN ACTION
            To configure an action, do the following:
            • Go to Configuration → Actions
            • From the page title dropdown select the required action type
            • Click on Create action
            • Name the action
            • Choose conditions upon which operations are carried out
            • Choose the operations to carry out
