Hello Folks,
We are doing POC for zabbix and today I have setup zabbix HA configuration Active/Passive, I have couple of questions on it.
Zabbix Cluster is setup on CentOS 7 with PCS maker, crosync and pscd services. My cluster is two node and I according to the documentation I have disabled the STOINTH, is that correct? My Zabbix application servers has two configurations, Web Front End and zabbix server configuration and I have added both these services under cluster controlled group, is it okay to put zabbix server and front end on same server? My configuration was working fine but I saw an issue today that zabbix httpd service was blocked but after starting the cluster services it was gone. Any idea why it had happened? If you guys can help me on these questions that would be great.
TIA..
Sent from my iPhone using Tapatalk
TIA..
