Zabbix Cohesity backup jobs monitoring
  • sajid4uu2c
    • Oct 2020
    • 24
    Hi All,
    I have added a Cohesity backup server with SNMP agent in Zabbix.
    It is currently monitoring CPU, Memory and Disk space parameters using the template "Template Module HOST-RESOURCES-MIB SNMP"
    I would like to monitor the backup jobs status as well like failed/successful. Could you help me and suggest if there any template available for the same or how to proceed on this. Thanks.
  • sajid4uu2c
    • Oct 2020
    • 24
    Hi Team,
    Could you please help on this.
    • mehdi.dev
      • Feb 2021
      Hello, pleae check the one i created recently.
      let me know if you need support.
      https://share.zabbix.com/cat-app/bac...ackup-solution
      https://github.com/mehdy-dev/zabbix-...ty-integration
      • doane
        • Apr 2025
        Do you have found any solution ?
        I'm trying to monitor Cohesity cluster via SNMP and I haven't got any good informations.
        Thank you for your reply.
