Zabbix proxy
  • ginesgb
    • Nov 2014
    • 23
    Zabbix proxy
    Hello everybody, I configured the proxy zabbix to connect different network segments, but I have a problem, and even responds to ping between the server and the next server but this fails in different segments monitored, giving the error:
    Received empty response from Zabbix Agent at [10.30.10.11]. Assuming That agent connection dropped Because of access permissions.
    What configuration error or permits should facilitate for I to do?
    A greeting and thanks
  • LenR
    • Sep 2009
    • 1011
    Is selinux turn on?
    • ginesgb
      • Nov 2014
      • 23
      Zabbix proxy
      Hi, thanks, yes Selinux is disable.
      Last login: Thu May 28 10:16:12 2015
      root@ZABBIX-PROXY:~# sestatus
      SELinux status: disabled
      • ginesgb
        • Nov 2014
        • 23
        Zabbix Proxy
        Hello good at all, I've been mulling over the server and proxy zabbix zabbix but although I have corrected errors remains unconnected.
        The error is:
        Get value from agent failed: cannot connect to [[10.10.10.10]:10050]: [4] Interrupted system call
        The current configuration I have, I get this error.
        I can monitor the Zabbix agent zabbix proxy server but the service conducting proxy for monitoring other machine does not do it properly or have a configuration error which is not currently have installed, after reviewing all.
        Zabbix server is mounted with a MySQL database and zabbix proxy server is mounted with a SQLite database.
        The error that is giving me the debug mode 3 is this.
        19324:20150603:143319.290 Please consider attaching a disassembly listing to your bug report.
        19324:20150603:143319.290 This listing can be produced with, e.g., objdump -DSswx zabbix_proxy.
        19324:20150603:143319.290 ================================
        19393:20150603:143319.328 Starting Zabbix Proxy (active) [ZABBIX-INTERNET]. Zabbix 1.8.11 (revision 26205).
        19393:20150603:143319.328 **** Enabled features ****
        19393:20150603:143319.328 SNMP monitoring: YES
        19393:20150603:143319.328 IPMI monitoring: YES
        19393:20150603:143319.328 ODBC: NO
        19393:20150603:143319.328 SSH2 support: YES
        19393:20150603:143319.328 IPv6 support: YES
        19393:20150603:143319.328 **************************
        19398:20150603:143319.348 proxy #4 started [poller #1]
        19397:20150603:143319.350 proxy #3 started [data sender #1]
        19399:20150603:143319.353 proxy #5 started [poller #2]
        19396:20150603:143319.354 proxy #2 started [heartbeat sender #1]
        19401:20150603:143319.356 proxy #7 started [poller #4]
        19402:20150603:143319.360 proxy #8 started [poller #5]
        19404:20150603:143319.360 proxy #10 started [trapper #1]
        19405:20150603:143319.362 proxy #11 started [trapper #2]
        19395:20150603:143319.363 proxy #1 started [configuration syncer #1]
        19406:20150603:143319.366 proxy #12 started [trapper #3]
        19403:20150603:143319.370 proxy #9 started [unreachable poller #1]
        19400:20150603:143319.371 proxy #6 started [poller #3]
        19407:20150603:143319.372 proxy #13 started [trapper #4]
        19408:20150603:143319.373 proxy #14 started [trapper #5]
        19411:20150603:143319.376 proxy #17 started [discoverer #1]
        19409:20150603:143319.376 proxy #15 started [icmp pinger #1]
        19410:20150603:143319.377 proxy #16 started [housekeeper #1]
        19410:20150603:143319.378 Executing housekeeper
        19393:20150603:143319.380 proxy #0 started [main process]
        19412:20150603:143319.382 proxy #18 started [history syncer #1]
        19415:20150603:143319.383 proxy #21 started [history syncer #4]
        19414:20150603:143319.384 proxy #20 started [history syncer #3]
        19413:20150603:143319.385 proxy #19 started [history syncer #2]
        19410:20150603:143319.532 Deleted 0 records from history [0.002537 seconds]
        19395:20150603:143319.538 Received configuration data from server. Datalen 8326
        19395:20150603:143319.539 Invalid field name "name"
        19408:20150603:143345.515 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:143545.535 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:143745.555 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:143945.574 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:144145.594 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:144345.613 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:144545.631 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:144745.651 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:144945.670 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:145145.689 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:145345.707 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:145545.726 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:145745.745 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:145945.764 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:150145.783 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:150345.802 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:150545.821 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:150745.843 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:150945.862 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:151145.881 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:151345.901 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:151545.921 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:151745.940 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:151945.961 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:152145.980 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:152346.000 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:152545.020 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:152745.040 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:152945.060 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:153145.083 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19410:20150603:153320.114 Executing housekeeper
        19410:20150603:153320.124 Deleted 30 records from history [0.001225 seconds]
        19395:20150603:153320.127 Received configuration data from server. Datalen 8326
        19395:20150603:153320.128 Invalid field name "name"
        19408:20150603:153345.103 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:153545.122 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:153745.142 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:153945.161 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:154145.180 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:154345.205 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:154545.224 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:154745.244 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:154945.263 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:155145.283 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:155345.303 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:155545.322 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:155745.342 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:155945.361 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:160145.380 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:160345.400 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:160545.420 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
        19408:20150603:160745.439 Sending list of active checks to [127.0.0.1] failed: host [ZABBIX-INTERNET] not found
