From reading through the forums it appears Zabbix had the ability to check and correct time issues prior to v4.0.
Has any of that functionality been added back in 5.x ? (5.0.2 is what I am using)
If Zabix would at least inform me that system time is out of sync then that would help. For ICMP monitored items and ZBX monitored items at least.
i am setting up agents on hundreds of systems but know that ntp is only set up on some of them so if Zabbix could identify the ones with improper time and possibly the ones not running any kind of NTP it would help greatly.
